Just installed Jira on a clean install of CentOS 6 w/ apache on it. I plan to also install conflunence and use virtual hosts to proxy the ports for both applications. However, after installing Jira ad starting the service, I am not able to access the installation through the server's IP w/ the 8080 port. I'm sure I missed something pretty obvious, but any guidance will certainly be appreciated!
Also, for anyone who can recommend certain things to avoid (or make sure to do) when installing both of these applications on the server w/ Apache, let me know!
--Eric
This looks more like ownership/permission problems. Are your directories owned by the same userid that the Jira process is running under? It could be the web server not having the proper access to the Jira directories.
As far as I can tell, yes. I used the express installer, so it created the directories under the "jira" user, right? I'm running the startup script under root.
Yes, but you need to physically check this. Make sure the directories it's trying to access are all owned by the Jira user, and have full r/w for that user and so-on
Just looked through the jira directory and sub direcories. everything is r/w for the user jira with the exception of "catalina.pid" in the work folder, which is owned by root.
That could be part of it, that file should also be owned by the jira user.
I think I got to the root of the issue, or at least, one of the big ones. From what I could tell, when I installed Jira, then Confluence, then Stash, I used the automated installer for the first two, which put them both in the same Tomcat container (correct?). I'm not all that familiar with Tomcat unfortunately, but certainly going to do some more reading up now.
So, I have a clean install of CentOS. Is it possible to install Confluence and then Jira using the automated BIN file, but making sure they are two separate Tomcat containers, so they don't interfere with each other?
I checked out this page: https://confluence.atlassian.com/display/DOC/Installing+Confluence+and+JIRA+Together
Which was helpful in explaining the situation, but doesn't go into any detail on making sure to install them so they won't interfere with each other, and they can still play nice.
Thanks gang!
--Eric
I'd be surprised if the installers put Jira and Confluence in the same Tomcat - that's explicitly stated as a bad idea on Atlassian's website!
You're absolutely right that they should be separate, and the BIN installers should create completely separate installations (including the Tomcats).
As long as they are installed in different locations (so as a really simple example, /opt/jira and /opt/conf for the installs and /data/jira and /data/conf for their "home" directories) then the only clash you might get is the ports - you need to make sure they listen on different ones. (e.g. Jira on 8080 and confluence on 8090, and Stash on 8075 or something). That's all in the server.xml for each one.
Gotcha. Alrighty, I'm going to follow through again, installing Confluence first this time, to see if that makes a difference, and I'll be sure to verify those ports both applications listen on. I'll be sure to post back one way or another with how things go.
Start with a look at the application log file - there are probably warnings or errors in there.
This is what I found in the startup logs:
2014-02-04 20:46:46,920 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2014-02-04 20:46:46,920 localhost-startStop-1 FATAL [atlassian.jira.startup.JiraStartupLogger] Startup check failed. JIRA will be locked.
2014-02-04 20:46:46,991 localhost-startStop-1 INFO [jira.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbconfig.xml
2014-02-04 20:46:47,475 localhost-startStop-1 WARN [jira.config.properties.ApplicationPropertiesStore] Exception getting property 'jira.trustedapps.user.name.transformation.policy.class' from database. Using default
2014-02-04 20:46:48,241 localhost-startStop-1 ERROR [jira.web.dispatcher.JiraWebworkActionDispatcher]
JIRA startup failed, JIRA has been locked.
Feb 04, 2014 8:46:48 PM org.apache.catalina.startup.HostConfig start
SEVERE: Unable to create directory for deployment: /opt/atlassian/jira/conf/Catalina/localhost
Feb 04, 2014 8:46:48 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
Feb 04, 2014 8:46:48 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 18713 ms
Hi Eric
The stack traces you are facing seems to related to the following knowledege base article:
Please give it a try and see how it goes
Hey Daryl,
Followed those instructions, unfortunately, same issue upon restarting Jira. I'm not sure if this is related, but Confluence is throwing this 500 error...
com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NullPointerException com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149) com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112) com.atlassian.confluence.setup.ConfluenceEncodingFilter.getGlobalSettings(ConfluenceEncodingFilter.java:45) com.atlassian.confluence.setup.ConfluenceEncodingFilter.getEncodingInternal(ConfluenceEncodingFilter.java:35) com.atlassian.confluence.setup.ConfluenceEncodingFilter.getEncoding(ConfluenceEncodingFilter.java:27) com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:38) com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44) com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:65)
If you think it's worth installing piece by piece overagain on a clean OS install, I can make better notes of what I do, and if the same issue
comes up again, hopefully that can help solve the issue, and anyone else who bumps into similar circumstances.
Let me know what you think.
--Eric
