Jira not showing worklogs created with rest
Siarhei Budkevich February 15, 2023
Created a small application for creating worklogs using Jira rest api V2.
Case:
1. POST create worklog => 201
2. Get issue by id => see newly create worklog
3. Updated Jira UI
Expected: see created worklog
Actual: there is no worklog
Which jira-server security configuration are responsible for this feature ?
Sachin Dhamale
@Siarhei Budkevich
Welcome to the Atlassian Community !!
When you are running the REST API for worklog, you should get 200 for successful hit.
201 - means its failing. Can try to run that on POSTMAN tool and check what output you are getting.
Accept answer if it helps
Sachin
@Sachin Dhamale Hello!
Honestly, i don't remember the code. Used curl to post worklog. But 100% it has been created.
Sachin Dhamale
@Siarhei Budkevich
How do you sure its been created if you are not able to see it on issue
Sachin
After POST creation curl request I send GET worklog curl request and see a new one there.
I saw in google, that it can be server security/visibility configurations. But haven't found any details about that
Sachin Dhamale
Perform the project indexing and check
