Jira project not showing up in Jira extension
Charles Cochener February 8, 2023
I installed Jira browser extension and logged in but the exact project I want to create task in doesn't show up. In my company, we have a lot of projects and yet only 7 of them can be selected from the Jira extension. Can someone please explain to me the reason of this please ?
Trudy Claspill
Hello @Charles Cochener
Which browser extension for which browser specifically did you install?
Is there a correlation between the types of the projects (Service, Software, Work Management) and what does or does not display in the extension?
Or a difference in the project architecture; i.e. Team Managed vs. Company Managed?
Charles Cochener February 9, 2023
Hello, thank you for getting back to me. The extension is called Jira Work Management and it opens a small pop-up that allows me to create tickets at any time.
After checking with your last recommandation, it seems indeed that only Team Managed projects are showing up in this extension. The project I am looking to add tasks in is a Company Managed project. Is it possible to access Company Managed project from this extension or do I need to request to change the type of this project ?
Trudy Claspill
I've not yet installed the extension myself to test. As I work on that, can you confirm that the Company Managed projects that you want to work with a Business/Work Management projects?
Business/Work Management projects show navigation across the top of the screen.
Software and Service projects show navigation on the left side, and say "Software" or "Service" at the top below the project name.
The extension currently applies only to Business/Work Management projects, not to Software or Service projects.
Charles Cochener February 10, 2023
Hello, thank you for your answer. Yes the project I am looking for is currently a software project. I am going to see with my team if it is possible to make it a work project. Thank you.
Muriel S_ Thiago Ledoux Rupp
OK I will uninstall the extension since I work in a Software project.
Hope you reach me out when it is availble.
