Jira project
Daniel Carrion September 2, 2013
I would like to know if there is a new instruction about jira project that can help me to know step by step how to use the jira project.
RicardoA
September 2, 2013
Hi Daniel
Please refer to this documentation:
https://confluence.atlassian.com/display/JIRA/What+is+a+Project
I believe it will help you.
Ricardo Carracedo.
Daniel Carrion September 3, 2013
Hi Ricardo i am very grateful for your quick answer, but in our company we are using the 5.2.10 jira version, the information that you sent us is a version newer. My problem is that i need to write a user guide for one coworker that are working in Honduras. So i need one guide in order to guide to my coworkers on the use of jira project since star to end.
thanks
RicardoA
September 3, 2013
Hi Daniel
In that case here is the documentation for 5.2.10:
https://confluence.atlassian.com/display/JIRA052/What+is+a+Project
Hope it helps.
Ricardo Carracedo.
