Jira projects and calendar view
Jacqui Carrigan
July 17, 2024
Are there any project types where calendar view is not available? I cant seem to find it on my software project.
Annie_DevSamurai
Hi @Jacqui Carrigan
Welcome to the community.
The calendar view is not available by default in Jira Software projects, which focus more on agile boards and backlogs. The calendar view is typically found in Work Management projects or can be added via plugins from the Atlassian Marketplace.
If you need a calendar view in your Software project, you may consider installing an appropriate add-on.
I'd like to recommend our TeamBoard ProScheduler and TeamBoard TimePlanner apps, which provide robust calendar functionalities and can seamlessly integrate with your existing Jira setup. These tools offer advanced scheduling and planning features that can enhance your project management experience.
Hope it may help!
Trudy Claspill
Hell @Jacqui Carrigan
Jira Work Management and Jira Software are being combined into a single product. The Calendar view will eventually become available in Software projects.
According to this documentation you should be able to access the calendar
https://support.atlassian.com/jira-software-cloud/docs/what-is-the-calendar/
