×Hi
i whould like to install a good report (prefer free) by
o Priority
o Regression
o component
Also to set score pre jira bug in each are ,the idae is if some componnent go over the threshold the componnent area will be red and mail will sen.
Ron
The first two columns can be achieved by using the Issue Statistics Gadget in a Dashboard (to have the extra columns based for score, you need to write one yourself)
And the second table using Two dimensional statistics gadget
https://confluence.atlassian.com/display/JIRA/Adding+the+Issue+Statistics+Gadget
https://confluence.atlassian.com/display/JIRA/Adding+the+Two-Dimensional+Filter+Statistics+Gadget
You'll need to define this a little more clearly, in two ways.
First, priority and component are standard system fields in Jira, so they're available to any reports. But what do you want from "regression" and "score pre Jira bug in each area"?
Second, the output - it's fine to ask for "a report", but you need to define what the report is. This is usually quite simple to get started with - "a list of the issues, sorted by area and component" or "a summary of statistics such as time-worked for a list of issues". But you need to define what you're trying to get out and how you want to see it.
I'd also separate out the "threshold" part of the requirement. What threshold is it? Time based? Effort based? What are the values and what are you comparing them with. I assume you'll want to highlight "over the threshold" issues on-screen.
I can tell you (without a specification I'm asking for above) that if you do this properly, you can easily filter for "over the threshold" issues. Once you've got a filter, you can push it through all sorts of reports, and use it as a basis for sending emails or even escalatiing issues further.
Thanks for the answer
Basicly i want to creat two kind of reports
Componnents bugs kpi report
score
Commponnent1=4 ; Commponnent2=5 ; Commponnent3=2 ; Commponnent4=3
Threshold
Component > 50 green
Component 100<>50 yellow
Component < 100 red
Issues |
score |
Threshold |
Commponnent1 |
30% |
120(4x30) |
Red |
Commponnent2 |
20% |
100(5x20) |
yelow |
Commponnent3 |
10% |
20(20x2)) |
green |
Commponnent4 |
40% |
120(3x40) |
red |
Status bugs report by filter
Priority |
Total # defects |
Open |
Resolved |
Closed |
Reopen |
In progress |
Regression (custom filed) |
Critical |
1 |
1 |
High |
22 |
13 |
5 |
2 |
1 |
1 |
10 |
Medium |
4 |
4 |
low |
Total |
27 |
18 |
5 |
2 |
1 |
1 |
10 |
Thnaks
Ron
