Jira seems to ignore Base Url
Alberto Cecchi
September 13, 2016
My JIRA software is installed on a host with a custom port http://JIRASERVER:8095 that is targeted by a reverse proxy configured as http://jira.myserver.com.
In the server option I set the base url to http://jira.myserver.com but JIRA keep sending attachments and images url as http://JIRASERVER:8095.
I installed the lastest JIRA version.
What can I try to do to solve the problem ?
Sincerely,
Alberto
Alberto Cecchi
September 13, 2016
SWorry but I don't have any "General Configuration" but "System".
I own JIRA software and not Confluence.
Anyway I already set the Base Url to the public one (http://jira.myserver.com) but it seems to ignore it and keep using the private one (http://JIRASERVER:8095)
noamdah
September 13, 2016
Check out this link.
Nic Brough -Adaptavist-
September 13, 2016
If you don't have "general configuration", how are you setting the base url?
noamdah
September 13, 2016
Make sure you configure the JIRA application base url to the relevant address:
Go to Admin->System->General Configuration
Click Edit Settings
Change Base URL
As you also wish to change the port from 8095 to 80 change server.xml:
<Service name="Catalina">
        <Connector port="8095"
                   maxThreads="150"
                   minSpareThreads="25"
                   connectionTimeout="20000"
                   enableLookups="false"
                   maxHttpHeaderSize="8192"
                   protocol="HTTP/1.1"
                   useBodyEncodingForURI="true"
                   redirectPort="8443"
                   acceptCount="100"
                   disableUploadTimeout="true"
                   proxyName="jira.myserver.com"
                   proxyPort="80"
                   scheme="http"/>
