×Hi,
I'm looking for the way to convey the Jira solution implementation in a graphic way.
Like show how the projects, components, teams and boards are related.
Is there any Jira own instrument for this or shall I use external tools and diagrams?
Thank you
Hi @Inna S
You may want to look into some 3rd party plugins. I believe the structure plugin may be able to assist you if you are looking for a table relationship view.
Hi @Fabian Lim ,
I'm looking for something different: to explain the relations between projects, boars, teams and sprints.
We are used to completely different and more straightforward structure, so need to find a way to explain the approach.
Maybe you can share your vision on what this graph will look like (e.g an image) and someone else can chime in for more recommendations.
