×After migrating the data from Jira cloud to Jira server, we have observed that for issuetype = 'subtask', the description field is giving below error message.
Kindly provide me your valuable suggestions
An error occurred whilst rendering this message. Please contact the administrators, and inform them of this bug. Details: ------- org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getHtml' in class com.atlassian.jira.web.component.subtask.SubTaskSequenceColumnLayoutItem threw exception java.lang.NullPointerException: null value in entry: actualSequence=null at templates/jira/issue/table/macros.vm[line 117, column 34] at org.apache.velocity.runtime.parser.node.ASTMethod.handleInvocationException(ASTMethod.java:342) at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:284) at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:262) at org.apache.velocity.runtime.parser.node.ASTReference.value(ASTReference.java:507) at
Hi All,
Atlassian recommended with the below solution which apparently fixed the issue. Please try it out from your end.
I have checked the information you provided and it appears that there is an inconsistency in your database. Thank you for letting us know that you already ran the integrity checker and performed a re-index.
Currently the issue looks to be related to the issuelink table, can you please take the following steps?
2. 3. select count(*) from jiradb.issuelink where sequence IS NULL;
5. 6. select * from jiradb.issuelink where sequence IS NULL;
8. UPDATE issuelink SET sequence = 0 WHERE linktype=10100 AND sequence IS NULL;
select count(*) from issuelink where sequence IS NULL;
returns to me 1442
so i should run
1442 times for every linktype that DDL "select * from issuelink where sequence IS NULL;" displayed for me ?
Hello Alex
You have run below query
After executing, you will be seeing the duplicate numbers in 'linktype' column.
Then you have to run 'UPDATE' query
UPDATE issuelink SET sequence = 0 WHERE linktype= {paste the duplicate number} AND sequence IS NULL;
By executing above query, it will eliminate the duplicate values. You have to keep running till the count to be shown as '0'
After that, please restart JIRA and you will be seeing all the sub-tasks
Yes! That's more understandable, it works like a charm without any restart! Thanks!
One issue here that is left - when user was mention another user i see accountuseerid:... how can i fix it ? it's trying to locate such ID by a new path (after we moved from cloud to server)
I am also facing the same issue.
Please try to add 'users' in user management with apt permissions and check if that fixes the issue.
set sequence = 0
Could you explain why this particular value? I don't want it to be magic.
Download this app Cloud Compatibility for Jira when user was mention another user i see accountuseerid:...
Ran into the same problem after an import of subtask links.
Managed to rectify the corruption by using issueLinkManager.resetSequences method (https://docs.atlassian.com/software/jira/docs/api/7.6.1/com/atlassian/jira/issue/link/IssueLinkManager.html#resetSequences-java.util.List-).
Here is a snippet:
def links = issueLinkManager.getOutwardLinks(issue.id)?.findAll { it.issueLinkType.name == "jira_subtask_link" }
issueLinkManager.resetSequences(links)
I recommend doing a full integrity check.
so am i. If anyone find solution, pls write here. I'll be happy
Hello
'Integrity checker' will not be quite helpful in resolving this 'sub-tasks' issue.
I have posted the steps i took to fix the issue. Kindly go through and let me know if you still face the issues.
