Jira ticket automation
Suraj Jha
August 10, 2024
Is there a way to automatically create a JIRA ticket from the issue name by searching all the previous tickets, and add the new media files in it too, by just uploading the new media files in a folder which has same name as the issue.
Victor Law
Hi @Suraj Jha,
Perhaps you may consider creating a manual trigger clone issue automation as below:
https://confluence.atlassian.com/jirakb/automation-how-to-clone-tasks-stories-along-with-their-sub-tasks-1235853548.html
Alternatively, you can manually clone an existing Jira issue or use the Issue Template app if you are considering creating the problem with a template.
Thank you.
