×Good evening all,
Upgrading Jira 8.2x to 9.x
Disabled addons everything is fine with the upgrade and it goes through but does not start.
Working on Windows 2019.
When looking at the logs
JIRA-Bootstrap ERROR [c.a.jira.startup.ComponentContainerLauncher] A fatal error occurred during initialization. JIRA has been locked.
com.atlassian.jira.InfrastructureException: Error occurred while initializing component 'com.atlassian.jira.plugin.JiraPluginPersistentStateStore'.
Caused by:com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericDataSourceException: SQL Exception while executing the following:Select pluginkey, pluginenabled FROM pluginstate WHERE (pluginkey LIKE ?) (ORA-00904: "PLUGINKEYIKE": invalid identifier)
Caused by...
Caused by: java.sql.SQLSyntaxErrorException: ORA-00904: "PLUGINKEYIKE": Invalid identifier
at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.findByLike(DefaultOfBizDeLegator.java:127)
I've restarted the server and removed add-ons. I know that Oracle is not appreciating the JQL term PLUGINKEYIKE and when searching for it in the database I get none. I get PLUGINKEY but not PLUNINKEYIKE. So I'm likely to think that this is the cause of the issue. Along the road, this term was recycled. However, I am not a DB admin so would appreciate some guidance.
Same issue…
any solution?
Hi, I have the same error from 9.4.0 to 9.12.1 Jira. What was your solution in the end please?
Binary Collation.
