Jira upgrade test using VM clone (6.4.6 to 7.5.x)
Marcus Kesper November 1, 2017
I'm planning a Jira upgrade from 6.4.6 to 7.0 to 7.5.x and want to test it first on a VM clone server.
Are there any implications to expect regarding licenses if both instances (prod/test) run in parallel for a short time?
2 accepted
Logan Hawkes
Also, be aware that there is a required interim upgrade from 7.0.x to 7.1.x. You'll have to go from 6.4.6 to 7.0.x to 7.1.x to 7.5.x.
Here's the official Jira upgrade matrix.
Marcus Kesper November 20, 2017
Thank you, wasn't aware. Is this because of JIRA gadget rendering change in 7.1?
Logan Hawkes
Yes, I believe so. Another warning: if Jira Service Desk is involved, the upgrade is more complex. There's a reason people hire consultants for these things.
Gonchik Tsymzhitov
Hi!
1. If it is clone, it will not affected.
2. And you can set developer license into /{jira_home_directory}/dbconfig.xml
2.1. You can get developer  license from my.atlassian.com.
Gonchik Tsymzhitov
