We are using JSU plug-in post function linked transition. When sub-task is all done, the parent task will be executed done transition. But different issue types has different workflows. So how can I restrict this?
Hi Jason,
In this case, you simply need to add this Post Function more than once. In each case, select Parent/Sub-Task, add your Sub-Task Resolved statuses to "conditional statuses", and then select one of the Workflows and the corresponding Transition to complete. If that Transition ID does not exist on the parent issue, it will simply do nothing and move on to the next post function.
Let me know if that works for you!
Evn
Hi @Jason Liu ,
You can apply the Condition(Does not allow the action unless all subtasks have resolution Done) on each workflow If you have a separate workflow for a separate issue type.
