Jira workflow problem with comments
shiv August 25, 2014
I am created on new workflow and screen schema in Jira and i assiend that to one new projeat, but when i am transitision the issue status from workinprogress to resolve popup windows is not opening for enter the comments.
please help me out how to do this.
Thnks in advence.
(Note - converted from comment on an old unrelated thread)
Nic Brough -Adaptavist-
August 25, 2014
In the transition from work-in-progress to resolve, what screen have you got for the "transition screen"
I suspect you have no screen at all in there, which means the transition won't ask you anything. Try naming a screen in there.
shiv August 26, 2014
Hi Nic Brough,
Thank you for the your response, clould please tell me how to add the naming screen to transirion.
i am totally new on the jira.
August 26, 2014
Edit the workflow, find the transition, set the transition screen to a screen that you want to use (comments always appear, so you can use a screen that has no fields on it)
shiv September 10, 2014
Thanks Nic it is working..
