Greetings
We are running JIRA software 7.2.4. According to the Atlassian documentation IE11 should be supported.
However we are experiencing some problems.
The sidebar of the kanban boards are greyed out and we are unable to view an issue by klicking on it in the board.
Also avatars are not showing at all (not just in the kanbanboard view).
I assume there is some setting in the browser that I should change?
I have verified that i have javascript enabled.
I have also disabled compability view, this did not solve the issues.
Any assistance is greatly apreciated
Hi had this same issue. Turns out it was an IIS issue with max length of URL segments: https://community.atlassian.com/t5/JIRA-questions/400-Bad-Request-when-linking-issues-after-upgrading-to-JIRA-7-4/qaq-p/587541
To solve the problem, you can increase the limit in the registry: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\HTTP\Parameters\UrlSegmentMaxLength
For more info on IIS HTTP settings, refer to https://support.microsoft.com/en-us/help/820129/http.sys-registry-settings-for-windows
maybe that can help you:
https://answers.atlassian.com/questions/14812542
if you host JIRA behind IIS:
http://stackoverflow.com/questions/27934411/images-failing-to-load-in-ie-with-dom-7009-error-unable-to-decode-in-console
also check GPO's, the "IE Compatibility View" and the "Enhanced Protected Mode" as it sometimes can make problems.
im sorry that i cant help you more, we're still on 7.1.x and i cant reproduce the error.
Regards
Thanks for your reply
I have switched off compability view as per Atlassian's instructions. I also tried switching off protected mode. Neither of these actions resolved the problem.
I will just try to ask Atlassian directly then...
Thanks for your time
If I reload the page once pressing F5, then everything except the avatars works
Tobias - I'm experiencing the same issue in IE 11 with a Kanban board. Did you get a resolution to this?
Also i get a lot of "unable to decode image at.... for the avatars
It works flawlessly with ff and chrome yes
Could this be of interest from the warning console:
AJS's create element functionality has been deprecated since 5.9.0.
No alternative will be provided
Use document.createElement() or jquery.parseHtml() or preferably use a templating library.
This occurs when I try klicking the issue to view details
