×Is it possible to use both LDAP and JIRA authentication in one single instance.
Hi Rashid
Yes, you just have to create two User Directories.
Cheers, Ricardo.
Hi Mohammed
You can use both, JIRA will distinguish then, there is a documentation you can follow here:
Just be aware that JIRA will consider always the first user directory containing a "duplicated" user.
Cheers, Ricardo.
Hi Ricardo,
Can I have LDAP authentication for Internal users and JIRA authentication for external users.
~Rashid
