LDAP and JIRA authentication in same instance
Mohammed Rashid
Is it possible to use both LDAP and JIRA authentication in one single instance.
RicardoA
July 21, 2013
Hi Rashid
Yes, you just have to create two User Directories.
Cheers, Ricardo.
RicardoA
July 16, 2013
Hi Mohammed
You can use both, JIRA will distinguish then, there is a documentation you can follow here:
https://confluence.atlassian.com/display/JIRA/Connecting+to+an+Internal+Directory+with+LDAP+Authentication
Just be aware that JIRA will consider always the first user directory containing a "duplicated" user.
Cheers, Ricardo.
Mohammed Rashid
Hi Ricardo,
Can I have LDAP authentication for Internal users and JIRA authentication for external users.
~Rashid
