Language translation option in JIRA for Issues
Jijo John
Is there any language translation available or can be done for cloud hosting similar to below plug-in?
I found below, which does not support on cloud hosting
https://marketplace.atlassian.com/plugins/com.atlassian.translations.jira.inproduct
Is there any alternative method for cloud hosting?
Any help will be greatly appreciated.
Jijo | TechNPoints
Jijo John
Thank you, can this be done while transitioning issue workflow [on the fly]. ie, In Progress -> Resolved [Language transition to X language permanant, if language option is set?]
Ellen Feaheny [AppFusions]
October 2, 2014
Hi Jijo -
This is also not on JIRA Cloud, but if you'd like to move to a managed hosted server solution, which is like the cloud in terms of convenience, but any plugin you want, can help with that as an alternative.
To the question:
SpeakMyLanguage Translations for JIRA allows you to translate the issue, fields, comments on the fly.. 30+ languages. Email info@appfusions.com to try it if interested.
Jijo John
Dear Folks,
Can anyone help me with your expert advice here please
