Limit issue creation by project role
Nils Althaus October 24, 2024
We want to limit the creation of all issue types except for one. We have a separate workflow for the issue type that the users are allowed to create.
I tried solving this with a custom script validator (ScriptRunner) on the creation transition, which I based off of an example script:
import com.atlassian.jira.security.roles.ProjectRoleManager
// the name of the project role
def roleName = '_project_admin'
def projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager)
def role = projectRoleManager.getProjectRole(roleName)
projectRoleManager.isUserInProjectRole(issue.reporter, role, issue.projectObject)
Unfortunately, this doesn't work right. When I try to create an issue with this workflow with a test user that doesn't have the role the issue is still created. I don't know anything about GroovyScript - what is going wrong here?
Samuel Gatica (ServiceRocket)
Hi @Nils Althaus
Try the following:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
import com.atlassian.jira.component.ComponentAccessor
import static com.atlassian.jira.issue.IssueFieldConstants.ISSUE_TYPE
def user = ComponentAccessor.jiraAuthenticationContext.getLoggedInUser()
def issueTypeField = getFieldById(ISSUE_TYPE)
def userRoles = projectRoleManager.getProjectRoles(user, issueContext.projectObject)*.name
def availableIssueTypes = []
if ("Users" in userRoles) {
    availableIssueTypes.addAll(["Query", "General Request"])
if ("Developers" in userRoles) {
    availableIssueTypes.addAll(["Bug", "Task", "New Feature"])
issueTypeField.setFieldOptions(availableIssueTypes)
As detailed in Doc Restricting Available Issue Types
Best regards
Sam
Nils Althaus October 25, 2024
Hi @Samuel Gatica (ServiceRocket),
this is the perfect solution for us. Thank you.
Best regards
Nils
Manoj Gangwar
Hi @Nils Althaus Welcome to the community!
You may use the Permission Validator on issue creation and select the project role to restrict issue creation.
I actually didn't think of that. In our specific case, this will work since the users who are not allowed to create the other issue types are in a different role with fewer permissions.
