×Is there a way to only display specific options/types of Linked issues to a certain Project? For instance, I want Project X to only display Linked issues: "is Delivered by" or "Delivers" options.
I went into:
However, this will affect all projects and I only want it on a specific project.
Hello! I'm in need for the same thing, did some of you managed to do the script?
I was also looking for the solution of this kind and found Enhanced Links. It actually works as expected - limits the types of links available. However, the problem is that Jira Cloud does not allow issue view panels to be turned off. This causes the necessity to display the regular panel with issue links (without limitation of which link types a user can select) and with the Enhanced issue links, where the limitation works as it is configured.
So, to me this app does exactly what it promises but due to the Atlassian policy, not to allow turning off issue view panels by apps, both panela in one issue view look bad from the user experience perspective.
The link to the app: Enhanced Links for Jira - Atlassway Customer Support - Atlassway
