Limit visibility of issues, e.g. an EPIC in a project to certain users
natalie.heintz
August 3, 2021
Hi Jira Experts
How can I assign a specific visibility for certain EPICS or STORIES within a project to certain users. I have created a issue security scheme, but I am not sure how I can assign this scheme to an individual "issue" such as a specific EPIC.
Piotr Zadrożny _Eyzee_
Hi @natalie.heintz
You need to:
  1. Create Issue Security Scheme with security level, and assign to that security level users you would like to have access to sensitive issues.
  2. You need to make sure the field Security level is addedd to Issue creation/editing screen
  3. You need to make sure that you have proper permission "Set security level" assign to every user that need to set such security level
  4. Also individual to be able to set security level need to be assigne to it himself. So using issue security scheme you cannot assign securty level "Only for Accountant group" when you are not a part of this level (Accountant group in this example)
Best regards,
Piotr
natalie.heintz
August 3, 2021
Hi Piotr
this is great, I will test it. What about if I have the need that a person in that project can for example only see one or two Epics and related tasks underneath within that project, by assigning the security level to it but this user should be excuded from seeing the rest (other Epics, Stories, etc)?
Best regards
Natalie
Alex Koxaras -Relational-
@natalie.heintz hi!
Set a default security level as well.
Alez
