×Use Case: We have a consultant that works for a customer that is being loaned to us to help work on a sprint due to their expertise. They essentially will be working as a team member on a given project. We would like to "limit" their availability to only view certain stories in the project as we do not want to expose all the work we are doing to essentially our "customer".
Can this be accomplished? We are even open to exporting the acceptable stories to a confluence page and restrict their ability to actually access JIRA.
Any help would be appreciated. Thanks!
Hi @JanaW ,
There are several ways to accomplish this.
One way is to implement issue-level security on your project. It basically adds an additional layer of security on your project that allows you to set visibility at issue level. Read more on how to configure this here.
An alternative would be to add a user custom field to your project screens where that allows you to add the user to the issues he/she needs explicit access to. Then update your permission scheme to grant the necessary permissions based on that custom field:
You'll have to grant several permissions this way though (browse project, assign issues, edit issues, comment, ... => everything necessary to be able to work) and - as the message in the above screenshot says: it has the unwanted effect that your project is suddenly exposed to any user of your Jira instance (not the issues, just the project name).
In terms of behaviour, the first option would probably require you to set the issue security to something like Internal only for all issues by default and you would need to set the security level to e.g shared externally for the exceptions. The second option allows you to do nothing specifically, just add the external user to those tickets he/she needs to see. And keep in mind that you potentially expose the project name to users that should actually not see it.
Thank you very much!!!
