It appears that one setting has been changed in our projet.
After doing the set up again AND enable the development panel back in configuration it is all good.
@Matthieu Kozicki Welcome! .
Could you let us know if others are working ? this is the only one not working ?
Nicolas
If you means other tickets, they all have the same problem.
Regards
the section is called the `Development panel` : https://support.atlassian.com/jira-software-cloud/docs/view-development-information-for-an-issue/
