×Hello,
I would like to create dependencies between 2 issues (link issues) within a template (automation). I only seem to have 2 options. Why can't I select a specific issue that blocks another one? Is it a restriction from a lack of permissions?
Thanks for your help,
Domi
You may find a lot of exemples that could help you on the following page, https://www.atlassian.com/software/jira/automation-template-library/rules#
