Issue:
To recreate:
Expected:
The Linked Issues field cannot be customized to appear in the Context Fields section in the new issue view, as you mentioned. This limitation is a known issue and has been reported by other users as well.
Currently, the Linked Issues field can be found in the "Issue Links" section below the description and above the comments on the new issue view.
While this placement is not ideal if you want to have it in the Context Fields section, it's the default location for Linked Issues in the new issue view.
You can consider providing feedback to Atlassian using the "Give feedback" option in Jira to request the ability to customize the Linked Issues field position in the new issue view.
In the meantime, you may need to accept the default placement of the Linked Issues field in the new issue view.
Thank you for the quick response, @Oday Rafeh. I appreciate the additional info and my options to move forward.
