×I am working on a SQL query to extract the projects their leads and the project category. I was able to extract this with the below query
select pc.id,pc.cname, p.id, p.pname from nodeassociation na, projectcategory pc, project p
where na.sink_node_id=pc.id and
na.source_node_id=p.id and
na.sink_node_entity='ProjectCategory' and
na.association_type='ProjectCategory'
order by pc.cname;
OR
select p.id, p.pname, p.lead, na.sink_node_id, na.sink_node_entity, pc.cname from jiradb.jiraschema.project p
left outer join jiradb.jiraschema.nodeassociation na ON na.source_node_id=p.id
Inner join jiradb.jiraschema.projectcategory pc ON na.sink_node_id=pc.id
WHERE
but there is a glitch in this. I have some projects which does not have any category my query doesn't extract those projects. I have looked into node association and there is no entry for that project for project category even with value null. It seems kind of not possible to me. If anyone is having a clue of how to do it. Please let me know.
Use outer join the get the lines with null values. It would be something like this
left outer join jiradb.jiraschema.projectcategory pc ON na.sink_node_id=pc.id
WHERE
Hey Alexey,
Thank you for response. Even with above query I am getting the exact same result as I was getting with my query, It does not retrieve the project with no category.
this is nice but is there any option to achieve below type of list
Project Key
Project Description
Project Lead
Project Lead Email
Project Category
Project URL
Project Create Date
Project Name
