Hi All,
I have an Issue Listener implemented as a type2 plugin.
Inside Jira, If i comment& update an issue using issue edit screen, this listener fires issue updated but not commented.
If i comment & update an issue using issue resolve screen, this listener fires issue updated as wellas issue commented.
Could we have any work around here so that I could handle both comment and update in issue edit screen?
Hi Timothy,
Didnt quite get you here. Can you help me out..
"you must make sure that it does not trigger an event." How can i ensure that an event is not fired when update happens?.
Hi Timothy,
Did you an update to an issue in your listener? If yes, you must make sure that it does not trigger an event.
JIRA does thrown both events when you enter a comment in the edit screen, however the comment is sent along the Issue Updated event in the IssueEvent object.
You can extract and process it in your event listener.
Tibor
Thanks Tibor for quick reply.
I did try it. However there is a problem there when i extract comment and process an action in issue updated event.
whats the problem?In Issue resolved screen, both issue comemnted and issue updated events are fired. Now my issue comment action is getting invoked twice!!
