Log work with groovy script issue
Sergey L
Hi
Here is a code:
CM = ComponentManager.getInstance()
worklogManager = CM.getWorklogManager()
for(int i=0; i<=4; i++) {
    worklog = new WorklogImpl(worklogManager, issue, null, issue.reporter.name, issue.summary, new Date(), null, null, 1*3600)
    worklogManager.create(issue.reporter, worklog, 0L, false)
OR
    params = WorklogInputParametersImpl
        .issue( issue )
        .startDate(new Date())
        .timeSpent('1h')
        .comment('123')
        .buildNewEstimate()
    result = wls.validateCreate( context, params )
    wls.createAndAutoAdjustRemainingEstimate( context, result, true )
And here is a result:
5 worklog entries, with 1 hour spent
but Logged: shows only 1 hour instead of 5 hours
latest script runner addon with JIRA 6.1
same results with JIRA 5.1.7
Any ideas?
Thanks!
Sergey
Sergey L
Solution is to calculate logged time manually
for(int i=0; i=4; i++) {
        worklogManager,
        issue,
        null,
        issue.summary,
        new Date(),
        null,
        null,
        1*3600
    issue.timeSpent = issue.timeSpent == null
        ? 1*3600
        : issue.timeSpent + 1*3600
Ryan March 1, 2018
Hi @Sergey L, I know this was from a while ago, but I just noticed your code is an infinite loop as you need i==4, not i=4, so it may be worth updating your comment.
JamieA
September 29, 2013
Probably some kind of jira bug. As you see in the work log tab all the entries are there.
I've seen similar bugs where it barfs if there is not at least a one second difference in the creation time. In this case though I tested that and it still didn't work. Maybe for some reasons it assumes that they're all the same entry.
InternalS May 28, 2014
Do you know any way to update estimated time?
Alex Augusto February 26, 2015
I am creating a issue and PostFunction like to get the value of the "Data da tarefa " (Type: Date Time) and "Tempo gasto" (Type: Number field) to automatically make a worklog.
Can you help me how can I do?
I'm not a developer and I have difficulties:
I would like to create the task the timestamp was:
Day 10 / February / 2015 and 3 hours worked
Sergey L
Hermann
The same results when "startDate" are differs
Anyway, "Logged" field should be calculated properly even if dates are the same
HermannS
What come to my mind: These work log entries are all at the same time. What if you use a startDate that differs in at least one hour for each?
