Logs for deleted project
Garrett Bolling
October 1, 2013
An individual has deleted a Jira Project. Where are the logs for the delected project? I would like to verify who deleted the project. Thanks
Nic Brough -Adaptavist-
October 1, 2013
Jira doesn't log administrative access like that. You might be able to get it from the access logs, depending on how you've set up logging, but there's nothing in the application that will capture it.
Timothy
October 1, 2013
You might only find it in the access logs. Other than that, zilch.
