Looking for Test Management plugin for JIRA
Babita Bisen
January 2, 2025
We already use JIRA in our organization and I am looking for plugin for Test management. Could you please suggest which is the best test management plugin?
Niharika _AIO Tests_
Hello @Babita Bisen ,
Here's a list of test management tools in the Atlassian marketplace, which you can use for comparison : https://marketplace.atlassian.com/search?query=test%20management
You can also check out AIO Tests.
Our customer reviews speak for our tool and support.
Our tool offers all the key features and boasts of an intuitive interface with zero setup time, short learning curve and comprehensive features ranging from AI based case creations, comprehensive reports, host of automation integrations, apart from capturing the daily need of testers of case authoring and executions. Please feel free to go through our documentation or setup a free demo with an expert, wherein we can answer questions on setup, pricing, releases apart from the product walkthrough.
Here is a short list of the key features and we keep adding more:
  • easy creation and import of test cases
  • AI Generated cases
  • linking to Requirements (Jira stories)
  • view of testcases from the Jira story view
  • organizing in Folders and Sets
  • efficient execution with analytical view of multiple test executions
  • easy recording of run defects and artifacts
  • inbuilt traceability and execution reports
  • a number of gadgets to view all information on Jira Dashboards
  • Integration with numerous Automation Frameworks (Cucumber, JUnit, NUnit, TestNG, Postman, Robot, Cypress etc.)
  • Cypress and Katalon Studio integrations
  • Jenkins and Azure Devops plugin
  • Extensive support for Cucumber
  • and much more...
Please feel free to reach out to us via help@aiotests.com
Niharika (AIO Tests)
Aron Gombas _Midori_
You should check out the apps in the QA and Testing category. The list is ordered by popularity, which means that unless you have some specific requirements you could should have a look at the apps in the first positions of the list.
Rupal Der
Hi @Babita Bisen
QMetry for Jira (QTM4J) offers you simple yet scalable Test Management capability within Jira.
Rupal.
Tomasz Korusiewicz_SolDevelo
Hi @Babita Bisen ,
If you are looking for a third-party plugin for your test management needs, a good choice might be “QAlity Plus - Test Management for Jira”, developed by our team at SolDevelo.
QAlity Plus allows you to create and manage test cases with remarkable ease. Test cases can be written and executed straight from the issue view, which allows for a quick and easy way to access your test cases.
Each test step can be accompanied by test data, expected result and test attachments.
Another QAlity Plus useful features are Repository and Test Execution:
Repository allows you to manage, filter and create test cases and place them in custom named folders.
Test Execution page manages the status of the executed test case including auto-generated bug description. It also allows to customize and create statuses (execution status names, colors) and view the lists of previously reported bugs during the past test case executions.
You can try out the app for free for 30 days through our marketplace page.
In case of any questions, I‘m open to any questions you might have! You can contact us via our customer portal or book a demo session with us under this link.
Have a great day,
Tomasz
SolDevelo Team
Manoj Gangwar
Hi @Babita Bisen Welcome to the community!
There are many add-ons available in the marketplace. I would suggest you to use any one of the below:
1- X-ray Test Management
2- Tricentis Test Management
3- TestRail
