Hi All
I would like to do project planning in Jira with the following minimum criteria:
Now I had "Advanced Roadmap" and "Gantt Chat Planner" on my shortlist.
What did you choose for project planning? One of them or another one? Which one?
Would you share what you choose and some key points?
Thank a lot for your opinion.
Anja
Hi @Anja Kornacki , welcome to the Community!
The features you mentioned are typically unique to “Gantt chart” solutions. While Advanced Roadmaps is an incredible tool for managing project portfolio, it lacks the “critical path” capability. There are some workaround like “issue flagging” or “issue link” that can be used to indicate blockers but that’s not exactly helpful to visualize critical path.
Another the option you mentioned is Gantt chart Planner, which I assumed you're referring to this app? https://marketplace.atlassian.com/apps/1227063/gantt-chart-planner-roadmap-timeline-for-confluence?hosting=cloud&tab=overview
Disclaimer: I’m part of the team that build project management apps for Jira and Confluence, so allow me to share a bit more about our apps.
You can learn more about the differences between WBS Gantt-Chart app and Advanced Roadmaps here to better weight your options: WBS Gantt-Chart for Jira vs. Jira Roadmap and Jira Advanced Roadmaps
I hope this helps!
Linh Pham
Thanx, Linh Pham, for your thoughts and help. I'll investigate a bit in WBS GC. Cheers, Anja
