Looking for plug in to post build number to JIRA ticket
Bobby Holmes
April 5, 2019
We are using Azure Dev Ops for builds and i would like the developers to start adding the build number to the JIRA story.  I have done this with other tooling so i want to see if there is a specific plug in that will work with this configuration.
Agnieszka Jozwiak _Appfire_
Hi Bobby,
I will be happy to provide more information TFS4JIRA (Migration and Synchronization) We also provide support throughout the process if needed. Kindly let us know if you have any questions.
Best,
Agnes
Petter Gonçalves
April 9, 2019
Hello Bobby,
I hope you are having a nice day.
I understand that you would like to integrate your Azure Dev Ops and your JIRA Cloud application together to link your Builds to JIRA Stories and get it synced automatically. Is that correct?
There are some plugins that allow you to perform the integration between both applications:
TFS4JIRA - Synchronization and migration
Opshub - JIRA Integration with Azure DevOps
Dev Info for JIRA
Let me know of one of the options above helps you.
