Loop problem created from watchers of e-mail issues
Athanassios Siaperas December 21, 2015
Hello everyone,
The problem I encounter is that in the getMail configuration of a certain project, whenever an e-mail is retrieved the project's mailbox is added in the list of watchers for the issue created.
As of this action for any comment added, the project's mailbox gets a notification E-mail which is then consumed again by the E-mail handler thus creating a loop.
Any suggestions?
Athanassios Siaperas January 12, 2016
There is an MS Exchange mailbox (and a corresponding Active Directory user), named "cs10-support".
This e-mail address is specified in the Notifications Scheme's "project e-mail address" (see screenshot below).
So it is used
  • As a sender (From) e-mail
  • As the mailbox from which e-mails are fetched through the corresponding Email Handler (currently, JEditor HTML handler)
The problem is, as mentioned, that whenever an e-mail is fetched and processed from this mailbox, the handler arbitrarily adds Cc: cs10-support@our.domain.europa.eu (well, actually, cedefop.europa.eu, but removing this for spam reasons). See screenshot 2 below.
image2016-1-12 13:28:7.png
Vasiliy Zverev
January 12, 2016
Do you have a jira user with this e-mail?
yes, but only by chance: Since it's an Active Directory user and JIRA users are synced from the AD.
Vasiliy Zverev
January 12, 2016
Is it allowed for this user to be a watcher? See project permissions.
Vasiliy Zverev
December 22, 2015
Why comment appears when smb is added into watchers list? In my JIRA this event is not commented. Maybe you have some customisation about this?
Athanassios Siaperas December 22, 2015
Dear Vasiliy, When the issue is commented or updated or closed based on the customized notification schema, e-mails are sent to the watchers (among others). What I can't find out is why the project's mailbox is added to the watcher's list in the first place
Vasiliy Zverev
December 22, 2015
Try to analise custom event listeners. Maybe you have one to do this. Inspect it in order to find usages of WatcherManager(https://docs.atlassian.com/jira/6.4.3/com/atlassian/jira/issue/watchers/WatcherManager.html)
I checked but there aren't any custom events fired nor any post function that causes the mailbox to become part of watcher's list.
Vasiliy Zverev
December 24, 2015
Could you explain what does it mean project's mailbox. It seems that you have a user with this mailbox. Is is rigth?
