Lost Admin Rights using JIRA with Crowd
Lane Maxwell
September 20, 2014
I'm using JIRA (v6.2#6252-sha1:aa34325), everything has been working perfectly except that when I just tried to authenticate as admin I keep getting a message "The password you entered is incorrect."  It's integrated with CROWD and I have the group of jira-administrators assigned to my user.  This was working for months but now I can no longer login as admin.  Here is the output from the atlassian-jira-security.log, as you can see it passes authentication when logging in, but fails with the same user attempting to elevate to admin.
2014-09-20 22:13:54,308 http-bio-8380-exec-9 USER 1333x226x1 mzhk7k x.x.x.x,127.0.0.1 / The user 'USER' has PASSED authentication.
2014-09-20 22:14:23,760 http-bio-8380-exec-9 USER 1334x258x1 mzhk7k x.x.x.x127.0.0.1 /secure/admin/WebSudoAuthenticate.jspa The user 'USER' has FAILED authentication.  Failure count equals 1
I've found this in the crowd logs:
2014-09-20 22:55:23,872 http-bio-8095-exec-19 INFO [plugin.rest.filter.BasicApplicationAuthenticationFilter] Invalid authentication for application with name 'jira'
This only occurs when attempting to elevate the privileges to administrator, user login works fine.  The settings in crowd.properties are correct.
Any thoughts?
3 votes
Lane Maxwell
September 20, 2014
Here's an update on this.  I had a special character '@' in my application.password.  I removed this and it is now working as expected.  Interestingly enough, the user authentication worked fine with this, but when attempting to elevate privs I would experiencing the issue.
I have SSO enabled via  com.atlassian.jira.security.login.SSOSeraphAuthenticator.
So, I suspect there is a bug in this particular use case.  To reproduce, use crowd with SSO enabled in Jira, with the @ sign at the end of your application.password attribute.  Sign in to JIRA with a user who has the group jira-administrators assigned to them in Crowd, and attempt to elevate to administrator.
William Crighton [CCC]
September 21, 2014
This has bit me before but I didn't bother tracking down what was wrong with my password, just limited the 'special characters' to those most command line parsers accept. Thanks!
