I've attempted to have AI reach out to Jira Goals/Projects (Atlas) via MCP but it doesn't have that functionality. Are there plans to add this tool to the existing MCP tools in the future?
Context:
While the project & goal updates allow for following (curating) on a per user and even on a tag basis, there is a need to take these granular updates out of the system and share with leadership and possibly add additional information for a single consolidated update.
It would be great to be able to consume the granular updates via AI (MCP) and then generate the content in the final format/tool.
As of now, the Remote MCP Server, Atlassian’s AI integration layer, is in public beta, but it does not yet support Jira Goals (Atlas) or Project-specific data via MCP. The only resources currently available via MCP are Jira issues, Confluence content, and Compass (if applicable).
What’s Available Today
What's Not Supported Yet
What You Can Do
Response provided by Jer-nee Consulting, an Atlassian Gold Solutions Partner. We're here to support you in your success, feel free to reach out if you have nay other questions or issues.
