Make a jira 5 plugin work on jira 7
Walid Djama August 1, 2017
we have developed a plugin for jira 5, and now we are migrating to jira 7 but the plugin is not working even after chaging the pom.xml.
after successfully generating the package and instaling the plugin on jira 7 all the modules are disabled.
Can anyone please show me how to fix this problem.
Best regards.
Walid Djama August 24, 2017
I created a new jira skeleton plugin with SDK 6.2.14, then I transfered the code inside it and replaced the deprecated methods with the new ones. The plugin is now running on JIRA 7 perfectly.
Thanks for your help.
Best regards,
Aleksandr Zuevich
August 1, 2017
What is the 'sga.ppo.view.pret.name' in your plugin?
it's a name of a web-item
Aleksandr Zuevich
August 1, 2017
Could you please provide us with the full web-item description from atlassian-plugin.xml?
There is :
<web-item name="sga.ppo.view.pret.name" key="generate-ppo-pret" section="operations-operations" weight="1000">
<label>Demande</label>
<tooltip key="sga.ppo.view.pret.description"/>
<description key="sga.ppo.view.pret.description"/>
<link linkId="manage-project-link">/plugins/servlet/viewpposervlet?reportId=Demande_${issue.summary}&amp;issueId=${issue.id}&amp;type=pre</link>
<condition class="sga.report.ppo.condition.IssuePPOConditionCDC"/>
</web-item>
Aleksandr Zuevich
August 1, 2017
Would the plugin be enabled if you change "sga.ppo.view.pret.name" and hardcode some value instead?
Thank you,
here is the error :
2017-08-01 12:55:59,691 UpmAsynchronousTaskManager:thread-4 ERROR admin 554x112x1 9g3var 10.51.228.135 /rest/plugins/1.0/ [c.a.plugin.manager.DefaultPluginManager] There was an error loading the descriptor 'sga.ppo.view.pret.name' of plugin 'ppo-reporting'. Disabling.
java.lang.RuntimeException: Unable to enable web fragment
at com.atlassian.plugin.web.descriptors.AbstractWebFragmentModuleDescriptor.enabled(AbstractWebFragmentModuleDescriptor.java:133)
at com.atlassian.plugin.web.descriptors.DefaultWebItemModuleDescriptor.enabled(DefaultWebItemModuleDescriptor.java:72)
at com.atlassian.plugin.web.descriptors.DefaultAbstractWebFragmentModuleDescriptor.enabled(DefaultAbstractWebFragmentModuleDescriptor.java:35)
at com.atlassian.plugin.manager.DefaultPluginManager.notifyModuleEnabled(DefaultPluginManager.java:1991)
at com.atlassian.plugin.manager.DefaultPluginManager.enableConfiguredPluginModule(DefaultPluginManager.java:1738)
at com.atlassian.plugin.manager.DefaultPluginManager.enableConfiguredPluginModules(DefaultPluginManager.java:1715)
at com.atlassian.plugin.manager.DefaultPluginManager.enableDependentPlugins(DefaultPluginManager.java:1227)
at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:1188)
at com.atlassian.jira.plugin.JiraPluginManager.addPlugins(JiraPluginManager.java:150)
at com.atlassian.plugin.manager.DefaultPluginManager.scanForNewPlugins(DefaultPluginManager.java:903)
at com.atlassian.plugin.manager.DefaultPluginManager.installPlugins(DefaultPluginManager.java:821)
at com.atlassian.jira.plugin.JiraPluginManager.installPlugins(JiraPluginManager.java:168)
... 3 filtered
Thank you.
Here is the error :
... 3 filtered
at java.lang.reflect.Method.invoke(Unknown Source)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy91.installPlugins(Unknown Source)
... 3 filtered
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207)
at com.sun.proxy.$Proxy1166.installPlugins(Unknown Source)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler$1.doInTransaction(AbstractPluginInstallHandler.java:143)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler$1.doInTransaction(AbstractPluginInstallHandler.java:138)
at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:25)
at com.atlassian.jira.DefaultHostContextAccessor.doInTransaction(DefaultHostContextAccessor.java:34)
... 2 filtered
at com.sun.proxy.$Proxy486.doInTransaction(Unknown Source)
... 2 filtered
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136)
at com.atlassian.sal.core.transaction.HostContextTransactionTemplate.execute(HostContextTransactionTemplate.java:21)
... 2 filtered
at com.sun.proxy.$Proxy1221.execute(Unknown Source)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifacts(AbstractPluginInstallHandler.java:137)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifact(AbstractPluginInstallHandler.java:123)
at com.atlassian.upm.core.install.JarPluginInstallHandler.installPluginInternal(JarPluginInstallHandler.java:52)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installPlugin(AbstractPluginInstallHandler.java:64)
at com.atlassian.upm.core.install.DefaultPluginInstallationService.execute(DefaultPluginInstallationService.java:117)
at com.atlassian.upm.core.install.DefaultPluginInstallationService.install(DefaultPluginInstallationService.java:91)
at com.atlassian.upm.install.UpmPluginInstallationService.install(UpmPluginInstallationService.java:97)
at com.atlassian.upm.core.rest.resources.install.InstallTask.installFromFile(InstallTask.java:156)
at com.atlassian.upm.core.rest.resources.install.InstallFromFileTask.executeTask(InstallFromFileTask.java:37)
at com.atlassian.upm.core.rest.resources.install.InstallTask.run(InstallTask.java:81)
at com.atlassian.upm.core.async.AsynchronousTaskManager.executeTask(AsynchronousTaskManager.java:124)
at com.atlassian.upm.core.async.AsynchronousTaskManager$1.call(AsynchronousTaskManager.java:102)
at com.atlassian.upm.core.async.AsynchronousTaskManager$1.call(AsynchronousTaskManager.java:99)
at com.atlassian.sal.core.executor.ThreadLocalDelegateCallable.call(ThreadLocalDelegateCallable.java:42)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.atlassian.plugin.PluginParseException: Unable to load the module's display conditions: Could not load 'sga.report.ppo.condition.IssuePPOConditionCDC' in plugin ppo-reporting
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeConditionImplementation(ConditionElementParser.java:95)
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeConditionImplementation(ConditionElementParser.java:29)
at com.atlassian.plugin.web.baseconditions.AbstractConditionElementParser.makeCondition(AbstractConditionElementParser.java:116)
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeCondition(ConditionElementParser.java:73)
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeCondition(ConditionElementParser.java:29)
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeConditions(ConditionElementParser.java:65)
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeConditions(ConditionElementParser.java:29)
at com.atlassian.plugin.web.baseconditions.AbstractConditionElementParser.makeConditions(AbstractConditionElementParser.java:57)
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeConditions(ConditionElementParser.java:57)
at com.atlassian.plugin.web.descriptors.AbstractWebFragmentModuleDescriptor.makeConditions(AbstractWebFragmentModuleDescriptor.java:72)
at com.atlassian.plugin.web.descriptors.AbstractWebFragmentModuleDescriptor.enabled(AbstractWebFragmentModuleDescriptor.java:128)
... 91 more
Caused by: com.atlassian.plugin.web.conditions.ConditionLoadingException: Could not load 'sga.report.ppo.condition.IssuePPOConditionCDC' in plugin ppo-reporting
at com.atlassian.jira.plugin.webfragment.JiraWebFragmentHelper.loadCondition(JiraWebFragmentHelper.java:45)
at com.atlassian.plugin.web.descriptors.AbstractWebFragmentModuleDescriptor$1.create(AbstractWebFragmentModuleDescriptor.java:169)
at com.atlassian.plugin.web.descriptors.ConditionElementParser.makeConditionImplementation(ConditionElementParser.java:86)
... 102 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sga.report.ppo.condition.IssuePPOConditionCDC': Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [sga.report.ppo.condition.IssuePPOConditionCDC]: Is it an abstract class?; nested exception is java.lang.InstantiationException
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1046)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:504)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:476)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:342)
... 2 filtered
at com.atlassian.plugin.osgi.spring.DefaultSpringContainerAccessor.createBean(DefaultSpringContainerAccessor.java:97)
at com.atlassian.jira.plugin.PluginInjector.newInstance(PluginInjector.java:27)
at com.atlassian.jira.plugin.webfragment.JiraWebFragmentHelper.loadCondition(JiraWebFragmentHelper.java:43)
... 104 more
Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [sga.report.ppo.condition.IssuePPOConditionCDC]: Is it an abstract class?; nested exception is java.lang.InstantiationException
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:150)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:89)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1094)
... 114 more
Caused by: java.lang.InstantiationException
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
... 116 more
Thank you.
Here is the error :
... 3 filtered
... 3 filtered
... 2 filtered
... 2 filtered
... 2 filtered
... 91 more
... 102 more
... 2 filtered
... 104 more
... 114 more
... 116 more
Aleksandr Zuevich
August 1, 2017
please share errors from atlassian-jira.log with us.
