I have 2 custom fields in issue creation page in jira. They are IP Release, IP Recipient. IP Release contains 2 radio buttons with 2 options "Yes", "No". IP Recipient is Multi line text box. My Requirement is if we select "Yes" option from IP Release , then IP Recipient should be changed to "optional" to "mandatory" and if we select "No" option from IP Release , then IP Recipient should be changed to "mandatory" to "optional"
custom fields Id s are
IP Release --> 12431
IP Recipient --> 12435
Yes --> 23832
No --> 23833
I am new to JIRA plugin development. Please help me to solve this one.
Thanks in advance.
Hi Nanda,
Please take a look on this post, which has very detailed instructions on how to achieve it.
-- Arthur Gonçalves
Hi, Nanda.
You can possibly do this using the "Behaviours" which is now bundled on the Script Runner: https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
Behaviours add-on does this exactly.
