Making a field mandatory using automation rule
Kasturee
Good day
Is it possible to make a field mandatory when setting up an Automation Rule on a Project. I have setup the Trigger and Condition on the Automation Rule but do not see an Action to make another field mandatory.image.png
Jack Brickey
Automation is an “after the fact” tool so it cannot be used in this manner. And Company manage projects you can use the workflow conditions and validator‘s to accomplish this type of task.
Kasturee
Thanks Jack.
Bill Sheboy
May 21, 2021
Hi @Kasturee
Are you asking how to make a field required during issue creation, or after creation make a different field required?
I do not believe that automation rules can do either of these things...
  • Fields can be made required globally for all projects, or using a validator in a workflow
  • After the automation trigger has detected the created issue, it is already created: you cannot retroactively make a field required
  • And I do not believe there is a way yet to modify a workflow from an automation rule
Best regards,
Kasturee
Thanks Bill. It is during issue creation that I want to make a field mandatory based on another field having no information captured. I do understand that this can be done via the workflow validator but it does not look a standard feature and may need to be done via an add-on I am assuming.
On Jira Server, we currently use "Behaviours" to do this but I need to replicate this in our Jira Cloud Test instance
John Driscoll
It looks to me like you may need a JSON metadata update.
https://support.atlassian.com/jira-software-cloud/docs/advanced-field-editing-json/
