×Hi there,
I am building up a JIRA - support project for different Atlassian Tools (JIRA, Confluence, HipChat). Depending on the selected component (either JIRA, Confluence or HipChat), different customfields shall be either "visible & required" or "invisible & optional" in the create process.
Case 1 - Initial situation:
- Field "Business Unit" = Hidden
- Field "JIRA Project Concerned" = Hidden
Case 2 - Component "JIRA" being selected:
- Field "JIRA Project Concerned" = Visible and mandatory
Case 3 - Component "Confluence" being selected:
- Field "Business Unit" = Visible and mandatory
Case 4 - Component "HipChat" being selected:
_Shall be handled as case 1_ (both fields invisible and optional)
In my opinion this is a standard case for the behaviours plugin, but after several hours and a lot of code changes, I ended up with following code, which simply does not work for us:
import com.atlassian.jira.bc.project.component.ProjectComponent
FormField components = getFieldByName ("Component/s") // id for Component
FormField BusinessUnit = getFieldById ("customfield_10572") // id for "Business Unit"
FormField JiraProjectConcerned = getFieldById ("customfield_10100") // id for "Jira Project concerned""
String component = components.getValue()
if (component == 17850) {
JiraProjectConcerned.setHidden(false)
else {
JiraProjectConcerned.setHidden(true)
Furthermore I optionally tried using following code in the initialiser script:
BusinessUnit.setHidden(true)
BusinessUnit.setRequired(false)
JiraProjectConcerned.setRequired(false)
The result of the first snipplet is always that field "JIRA Project concerned" is hidden and will never show up, so the else-case seems to always true.
As mentioned it took me already a lot of time, being non code-savvy, so I'd be more than grateful to have any concrete hints into the right direction.
Thanks and best regards
Kai
PS: Already had an intense look into the documentation of the plugin at Adaptavist and in following questions here:
@Jamie Echlin (Adaptavist) solved my question with this comment/link:
That particular example is covered here: https://scriptrunner.adaptavist.com/latest/jira/recipes/behaviours/select-list-other.html
So thanks a million once again, Jamie!
Dear team,
In my Jira project's create screen, need to make LOCATION field mandatory only if Component/s Field's drop down value is "Cloud Test Lines" is selected..
Please help me with script or steps detail as I am a new bee to Jira.. It will be great help if you people direct me to get it solved immediately.
Anusha
Hi Kai
You can try something like this.
import com.atlassian.jira.bc.project.component.ProjectComponentImpl
def components = getFieldById("components") // id for Component
def JiraProjectConcerned = getFieldById ("customfield_10200") // id for "Jira Project concerned""
def component = components.getValue()
ProjectComponentImpl componentImpl = component[0]
if (componentImpl?.getName()?.equals('17850')) {
else {
JiraProjectConcerned.setRequired(true)
Please let me know if this works for you
Regards
Hi Thanos,
first: Thanks a million for pointing us into the correct direction!
With your script example above, I finally got it working 90% of our requirement, using this script:
def JiraProjectConcerned = getFieldById ("customfield_10100") // id for "Jira Project concerned"
def BusinessUnit = getFieldById ("customfield_10572") // id for "BusinessUnit"
if (componentImpl?.getName()?.equals('JIRA')) {
else if (componentImpl?.getName()?.equals('Confluence')) {
BusinessUnit.setRequired(true)
else if (componentImpl?.getName()?.equals('Hipchat')) {
The only missing thing here is that instead of removing fields ("JIRA Project concerned", "Business Unit") when a certain component is chosen, I wanted to remove the fields initially and then want to show them, once a certain component is chosen. My assumption was using the initialiser function for this, but it simply does not work. Any hint here for me?
Thanks a lot —
Cheers
Kai
If you want to show them when a component is chosen, you have to add the script to the component field, not initialiser.
Hi Jamie, first of all thanks a lot for the best plugin available in Marketplace: Script Runner. We're using it for more than three years now, and - since three days - acquired a paid license ;) The above mentioned script is currently entirely attached in the "Component/s"-field and as stated I have following situation: as is: ------- 1.) Initially both fields ("Business Unit"/"JIRA Project concerned") are shown. 2.) Once a component (e.g. "JIRA") is entered the field not used ("Business Unit") DISAPPEARS. to be: -------- 1.) Initially both fields ("Business Unit"/"JIRA Project concerned") are NOT shown. 2.) Once a component (e.g. "JIRA") is entered the field used ("JIRA Project concerned") APPEARS. Is this doable? What I need to change in this script? Cheers Kai
I'm also wanting to use Behaviours to control the visibility of other fields, depending on the value in a select box. I haven't yet tried to script it, but will be trying later today.
So if anyone has a solution or pointer for this problem, I'd be grateful. If I can get it working, I'll post my solution here as well.
Hi Team,
I too have a similar kind of Issue, could you please help me?
I want to make Custom Field (Software) mandatory upon Component value as "software". I have tried followng code, but it didn't work:
def Software = getFieldById("Software") // id for "Software""
if (componentImpl?.getName()?.equals('software')) {
Software.setRequired(true)
else {
Software.setRequired(false)
