Making "Fix For" required for resolve screen
Neal Culiner
November 13, 2013
I'm using JIRA 6.1.3 and I'd like to enforce the "Fix For" version to be required during a resolve workflow/screen. Right now if I make "Fix For" required then the developers have to set this in the create issue screen. I spent some time working with the various admin area items in the Issues area but could not figure out how to make this happen.
Any suggestions would be greatly appreciated.
Thank you.
Rahul Aich [Nagra]
November 13, 2013
Workflow validators (JIRA suite utilities plugin).there's one option as "field(s) mandatory".
Make sure you add the field in the respective transition screen.
https://answers.atlassian.com/questions/125775/how-can-i-make-fields-required-on-a-transition-screen-but-not-required-on-the-edit-screen
Tahmina Khan
November 20, 2018
So I'm able to to add a workflow validator and it works. But I was trying to Validated that a Story point is populated only when it goes through a "Fixed-Done" resolution. But it should be required if the story is "Cancelled" How would I go upon that? I was not able to find something for it.
rambabu patina
November 13, 2013
Udo Brand
November 13, 2013
use a field required validator in the resolve transition and add a screen with the "Fix For" field into that transition.
