In Scrum i have
Themes, Features and Epics, Stories & Tasks
In JIRA I have Epics, Stories & Tasks
How do i show Themes and Features in Jira, including where a feature may contain several epics?
At the moment i have Themes done with the components field. I'm considering Features with the labels field or another custom field.
What would you recommend?
Many thanks
Stuart
Hi Stuart,
Where in JIRA would you like to see your Themes and Features?
You can group Epics in any number of higher levels with our Structure Plugin (here's a blog post about doing just that: Managing JIRA Agile Projects in Structure).
This lets you visualise and manage the Theme-Feature-Epic-Story-Task relationship along with aggregation of times, estimates, progress, etc.
If you need to filter issues by Themes and Features, this can be done using an S-JQL query on a structure containing issues arranged in the TFEST hierarchy (example in the second half of this post).
In JIRA Agile, you'll be able to see the Themes and Features that a story belongs to in the Structure widget in the issue details panel, but there won't be any identifying labels (like the Epic label) on the issues in the boards.
Robert
