Hi!
When I link to "Find new apps" in Jira or Confluence, I see next information
"Oops! Looks like something went wrong while initializing.
What could be the problem?
Hi Community,
I found an example of a user with this issue in the Cloud support queue, and the issue was with a Google Extension named UMatrix and also an Ad Blocker add-on they were using in their browser.
Could you check if you have any ad blockers? If that's not the case, then you can try disabling all of your add-ons in your browser. See if the issue goes away. Then you can re-enable them one at a time until the issue returns.
Fabian Alfaro
This error concerns the HTTP header Referrer-Policy.
In my case, the Private Internet Access VPN plugin caused the error. The solution was to de-select the "Disable website referrer" option in the plugin's settings. I also found that
In brief:
Hi, the same happens to me.
Had this issue too using Brave browser.
Disabling shields for the site fixed it...
Yeah Same here! Really Annoying. I have been scouting the internet for a solution. Seems a ticket would be the right answer. I am also on Cloud.
Same error when integrating with GitHub.
