×I am working on a Jira Utility which extracts data using the filter ID.
I want to understand is there is a max & min limit for these filter IDs. For e.g. In Jira Cloud I have noticed that it starts from -9 to -1 and then jumps to 10000, 10001 and so on.
This will help me putting in some validations on the filter IDs provided by the user.
Hello @[deleted] ,
It is using a DB feature for auto-increment keys somewhat described in:
The description of how the application handles the auto-increment sequencing value across batched items in the database can be seen at:
and the following Developer community post discusses the default filter ids as a really good referance point as well:
Hope this help
Earl
Thank You Earl for your answer, it was quite helpful.
Aditya
