×Hi Sai,
I don't believe Atlassian publish a maximum limit for workflows.
However, they publish a sizing guide here which states that they class a large instance as having between 800 to 1,800 custom fields.
I hope this helps.
Kristian
Hi, there is no hard limit for customfield. You can create as much as you want the only issue could be the loading time of your instance
