Maximum How many custom fields we can create in JIRA Cloud
Sai November 2, 2023
Maximum How many custom fields we can create in JIRA Cloud is there any limitations
Kristian Walker (Adaptavist)
Hi Sai,
I don't believe Atlassian publish a maximum limit for workflows.
However, they publish a sizing guide here which states that they class a large instance as having between 800 to 1,800 custom fields.
I hope this helps.
Kristian
Mohamed Benziane
Hi, there is no hard limit for customfield. You can create as much as you want the only issue could be the loading time of your instance
Tuncay Senturk _Snapbytes_
Hi @Sai
Welcome to the Community!
Please take it with a pinch of salt! Here it says;
You can create up to 50 custom fields in your project.
