Method for communicate between JIRA
Heshan Manamperi
March 8, 2012
Does any one knows how to communicate JIRA instances. Is there any plugin or new API or something. JIRA 5.0 also can be consider.
Radu Dumitriu
March 8, 2012
My plugin
https://plugins.atlassian.com/plugins/com.keplerrominfo.jira.plugins.jjupin
knows how to handle remoting between multiple instances of Jira (via SOAP).
For simple tasks, you can rely on the REST interface Jira is exposing. There are some examples on how to achieve that.
Dieter
March 8, 2012
Heshan Manamperi
March 8, 2012
Yes Renjith, I have tried with scripting and CLI, But no in detail referances. Its need to sync issues automatically.
Renjith Pillai
March 8, 2012
What do you want to achieve between the instances? Is it a sync between the instances?
