×Is it possible to move Jira filters and dashboards from one Jira Server instances to another? we are in the process of moving projects from one Jira software server to another using the project import so we were hoping to move our dashboards, filters and boards if possible
You need to re-create filters and dashboards on new instance. Jira don't provide out-of-the box solution for that.
There is an add-on that you can use - https://marketplace.atlassian.com/apps/1211147/project-configurator-for-jira?tab=overview&hosting=server
Seba
Thanks, Seba for the response.
I'll definitely make use of the recommended add-on.
Quinton
