I need to a couple projects from one cloud instance to another. Or at least move the issues within each project.
I don't want to move entire instances and that seems to be the only way I can find that will accomplish what I need but I'm hoping to be proven wrong.
Hey @bdutchak
Try doing a CSV export/import.
If you go to the issues you would like to move in the right hand corner you will see a couple options. (Image 1) You can export specific fields as well from your issue filter. Then when you have the CSV downloaded, go to your other Cloud instance and do the second Image (image 2) and follow the steps on the importing from CSV process. If you need any help with that just let me know! Hope this helps :)
Thanks for that. It was a bit helpful. I found with the lack of field mapping options and slight variations of account names between instances, it was just easier to copy the data manually from the csv file.
