Hi Support,
I'm needing help with migrating 1 project from a Jira cloud account to a new Jira instance with our using Jira Server. Do you currently have the ability to move 1 single project over to a new Jira cloud instance?
Jacie
Currently, it's not possible to export a single project to import to another instance.
We have a feature request suggesting the implementation of such ability:
- https://jira.atlassian.com/browse/JRACLOUD-34307
If the new instance does now have any projects in it yet you can do this: https://confluence.atlassian.com/jirakb/how-to-migrate-projects-from-one-jira-cloud-application-to-another-779160766.html You can remove all the users in the XML, so only projects will be imported and your users won't be notified.
Otherwise you can create a project in the new instance, export the CSV of all tickets of the desired project and import in this new project. You can check our documentation for more details: Importing data from CSV
