mutableIssue.getGenericValue is deprecated in 5.0, but what should I use instead?
For example:
GenericValue changedIssue = updatedIssue.getGenericValue();
IssueUpdateBean issueUpdateBean = new IssueUpdateBean(changedIssue, originalIssue, EventType.ISSUE_UPDATED_ID, currentUser);
AND
updatedIssue.store();
Thanks!
no need to use the generic issue use the following constructer to instanciate IssueUpdateBean class
IssueUpdateBean(Issue changedIssue, Issue originalIssue, Long eventTypeId,com.atlassian.crowd.embedded.api.User user)
Rambanam
A MutableIssue is an Issue!
Cool, it works:)
Can you tell me how to get Issue from MutableIssue object? 'cause I have all methods with MutableIssue arguments..
Yeah, got it, thanx
But how can I make store() for MutableIssue? (The method store() from the type OfBizValueWrapper is deprecated)
mutableIssue.store();
You should use IssueService to update an issue instead of using the store method.
http://docs.atlassian.com/jira/latest/com/atlassian/jira/bc/issue/IssueService.html
if you want to update issue use the following method
issueManager.updateIssue(authenticationContext.getLoggedInUser(),mutIssue,EventDispatchOption.ISSUE_UPDATED,Boolean.FALSE);
if you want to set current workflow step to issue use mutableIssue.setWorkflowId(Long workflowId)
and use update method to update issue
Depends on what you're trying to do to the issue...
For example adding the comment to the issue.
I thought its not important. I mean - if the getGenericValue is deprecated, so I have to:
1) use some method for getting genericValue, that is not deprecated (but I can't find such method)
OR
2) find methods that I want to use with this issue, but those who will not use the GenericValue as an argument.
For ex.: issueUpdateBean(...), PluginUtils.updateIssue(GenericValue, Issue, String), PluginUtils.setCurrentWorkflowStep(GenericValue, String, String), and so on).
Can you help me with those methods please?
